You also need to switch the green dropdown to Manual in your screenshot.Teken wrote:For the benefit of others who may stumble upon this thread and need to do the very same. When Ben indicates the CT Type / CT Range needs to be manually adjusted. You will select the channel in question (In Red) then change the CT Type / CT Range values (In red) to the desired numerical values to obtain the most accurate readings.
Net Alias can't exceed 25 characters error when saving
Re: Net Alias can't exceed 25 characters error when saving
Doh . . . I highlighted it earlier but must have snapped back to the previous setting. I'll reload it again didn't even notice that!ben wrote:You also need to switch the green dropdown to Manual in your screenshot.Teken wrote:For the benefit of others who may stumble upon this thread and need to do the very same. When Ben indicates the CT Type / CT Range needs to be manually adjusted. You will select the channel in question (In Red) then change the CT Type / CT Range values (In red) to the desired numerical values to obtain the most accurate readings.
For the benefit of others so they don't need to scan hundreds of threads to find this specific information there is a sticky thread on this process: http://www.brultech.com/community/viewt ... =29&t=1812
