Node Server Support
Re: Node Server Support
I hardly disagree with io_guy's assessment. My advice is to create it, not only will this create a method for those of us that wish to use the new PolIsy to interface between Brultech and ISY, but it will also in many people's environments remove a device from our network setup (that extra raspberry Pi or computer) Node Servers are how things are going to move forward with ISY and UDI. Having everything housed on the PolIsy using Polyglot makes for a less complicated install everything housed within one environment. Having a Brultech node server means that any code changes that Brultech
Having a node server is exactly what we are missing to directly interface from the Dashbox to the ISY/Polyglot interface. Of course we could just do it with REST commands and through variables, but then I appreciate the things that io_guy has done in the interim with NodeLink.
Thank you Ben and Barry, but I would position that a nodeserver for Brultech is sorely needed.
Oh I agree - So needed Ben did you look into it ??
...Barry
...Barry
Node Server Support
Hi Barry,bgrubb1 wrote:Oh I agree - So needed Ben did you look into it ??
...Barry
Ben and I actually talked about this - just today. There is no current ETA but it’s on the teams radar for development for sure!
Right now the team is working toward squishing remaining bugs and updating the Dashboard layout. I’ve asked them to add some more improvements on the alert messaging system currently in place.
Once there, this should offer more conditional operators flexibility in how and when the system relays alerts similar to the ISY. They are also working toward more refinements in the billing section for members like Mwareman and others.
Trying to get the new WeatherFlow and some Sky data working for the next update also.Teken wrote: ↑Fri Jun 26, 2020 7:18 pmHi Barry,bgrubb1 wrote:Oh I agree - So needed Ben did you look into it ??
...Barry
Ben,ben wrote:Trying to get the new WeatherFlow and some Sky data working for the next update also.Teken wrote: ↑Fri Jun 26, 2020 7:18 pmHi Barry,bgrubb1 wrote:Oh I agree - So needed Ben did you look into it ??
...Barry
As always, I and everyone greatly appreciate your endless development and stellar support!
I could not have accomplished this much in the Energy Monitoring, Energy Management, and Home Automation space without Team Brultech!
Much thanks goes out to Tammy, Paul, and You!!
Ben, did this ever make it up the TODO list ??
...Barry
...Barry
Yeah, I have a half-written library I have to get back into.
thank you Ben
...Barry
...Barry
Understanding this a bit more now. Sounds like the secondary device is doing all the heavy lifting nowadays.io_guy wrote: ↑Fri May 22, 2020 8:42 amTo create a Node Server for the ISY involves more than just the REST command for status.
A set of 3 files (Node Definitions) need to be created and uploaded to the ISY. After that the Brultech would need to send commands to add the various nodes to the ISY (which is dynamic based on the channels/sensors/counters configured in the Brultech) and then it would send a REST command for each value update on the GEM (separate REST sends for each value change).
My advice, don't do it. The ISY has completely moved 3rd part support over to Node Servers. Virtually no one will own an ISY and not have a secondary device (Computer, Raspberry Pi or Polyglot). You're better off just having one of these devices be the middle man since it's going to exist anyway.
For those unaware, NodeLink support should already work via the DashBox. Make sure your GEM is running Packet Format #4 (Bin-48-NET-Time) and enable Packet Forwarding under Add-ons->Packet Forwarding. If a persistent connection is required, checkmark the box. It'll forward every packet the DashBox takes in to NodeLink.
EDIT: Scratch that NodeLink, I'll have to look into having secondary ports to read packets.
I can modify NodeLink if it makes life easier. For example I could setup NodeLink to support sending data to the Dashbox.
FYI,
Right now I support formats 2, 4 and 14 (and 3 in the next version). 4 actually isn't great as the packets seem to come fragmented from the GEM and since it's byte format I can't find an EOL character to stitch it back together.
FYI,
