Re: Can i micro-calibrate CT's showing incorrect watts?
Posted: Mon Dec 19, 2016 12:41 pm
-Yes, i have moved the CH1/CH2 CT's to bottoms... no change
-All my channels are loaded with CT's... it was just removed to temporarily test.
/fj
/fj
ben wrote:A channel with no CT may pick up noise. Unused channels you can set the CT Range higher in order to zero those values out (CT Range doubles/halves the value).johnstonf wrote:I did a bunch of testing on a specific channel, and even with NO CT attached, I'm getting noise. With the CT (Micro-80) connected, I tried moving the cables around, away from all power lines, with/without jumper, etc, still noise! On ANOTHER channel, the jumper stopped the noise... it's hard to figure out!
A 'LOT' of my channels have noise, but not all!
/fj
Did you try moving the CH1/CH2 CTs to the bottom two ports of the channel?
