Wi-Fi and other data issues
cvachon79
Re: Wi-Fi and other data issues
Post by cvachon79 » Thu Nov 10, 2016 8:49 pm
It is an access point connected through Ethernet. Maybe the "mesh" technology / protocol is causing interference.
Post by Teken » Thu Nov 10, 2016 8:52 pm
Connect the GEM directly to the router and let us know the outcome.
cvachon79
Post by cvachon79 » Fri Nov 11, 2016 6:24 am
Hi Taken - it is an access point but I'm sure it's compatibility issue with the open-mesh system OR I have very bad luck and tried 2 bad power supplies... My access to the GEM via the web interface is very intermittent. I did take screen prints of every GEM menu if you think they would be of value.
However I did upgrade my DashBox and was able to connect to the GEM using port 8001. I updated my packet send to Bin48-NET-Time on the GEM and the DashBox now identifies the GEM.
Post by Teken » Fri Nov 11, 2016 8:23 am
That's perfect glad your connected now. But to be clear you have streaming data coming into the DB now right?
Also for informational purposes only. When you try to connect to the GEM's setup web page you will notice it can take 3-5 times before the page actually loads.
I don't recall what the problem is exactly but it's not a user issue so much as a system issue in how the GEM renders the page initially.
If you use google chrome browser you will see one of several rendering issues:
Web page shows it's downloading some kind of file / link.
Web page shows jibberish streaming across.
Web page shows only half the page.
My personal experience is to make sure 115200 baud is set up. Be patient and let the page load which can take 5-30 seconds. Lastly keep clicking the refresh page while waiting 20-30 seconds between.
Now what's going on with that 1 wire?
Post by ben » Fri Nov 11, 2016 10:23 am
cvachon79 wrote:Hi Taken - it is an access point but I'm sure it's compatibility issue with the open-mesh system OR I have very bad luck and tried 2 bad power supplies... My access to the GEM via the web interface is very intermittent. I did take screen prints of every GEM menu if you think they would be of value.
Are you using the WiFi-only or WiFi/Ethernet GEM?
If WiFi/Ethernet, what encryption type is it set to? We've had instances where we had to use AES but it detected it as TKIP.
cvachon79
Post by cvachon79 » Fri Nov 11, 2016 3:02 pm
Ben - I have the WiFi-only GEM. I'm using WPA2.
Post by ben » Fri Nov 11, 2016 4:15 pm
cvachon79 wrote:Ben - I have the WiFi-only GEM. I'm using WPA2.
Looks like the WiFi module supports up to G. Does the AP support Wireless G?
