I purchased a GEM 2 years ago, and it has been working fine. I've been connected to SEG, but am trying to setup the Stand Along Dashboard, which I'm having problems with, but will create a different topic for.
In the mean time, I'm decided to try to upgrade the GEMs firmware. Here are my current versions/setting from the GEM status page:
Current Settings
Serial#: 01000580
COM firmware ver: 2.40
ENG firmware ver: 0.0
RealTime Status: ON
Packet Send Interval: 30
Pri. Packet Format: 3
Sec. Packet Format: 0
Sys Status: OK Buffer Max: 2047
Chunk Size: 2047
Inter-Chunk Time: 22
Date/Time: 2015-10-24 02:20:12
COM1 Flow: OFF
COM2 Flow: OFF
Current Constant: 222
Sys Info: 00100001 OK
Sys Flags: 00000000 OK Keep Alive String:""
COM1 Baud: 115200
COM2 Baud: 19200
Phase Setting: Single Phase
Freq: 60Hz
Hardware Configuration: 136
Ethernet with connector board
Where do I get the firmware upgrade files? I logged in brultech.com and went to the download pages, but didn't see the firmware.
Upgrade GEM firmware
Re: Upgrade GEM firmware
When you enter the software section to the top right is a silver gog that says *firmware*.
You must be logged into this section to obtain the Engine / COM firmware.
I did login, but didn't see it, Maybe I entered my GEM serial number wrong or something. Is there a way to view my profile to verify?
Ok. I created a new user and entered my serial number again, and now I see the firmware.
Thank you.
Thank you.
Excellent, have a great week end.
