Hi All
Bought ECM-1240's in 2010. Recently bought GEM and Dashbox. I used my Split 200's from the ECM's connected to Ch32. The two CT's are installed on two hot legs facing same direction and connected to terminal pins 1-2 and 3-4.
The Channel CT is set to 144 /2 and Multiply by 2 is checked (has 1 in 240v column)
The power on this channel is way lower than just my AC channel
My voltage also says 97.9 (PT is at default of 238 / 4). Can it really be that low? My Furman UPS fluctuates around 120v (+/- 1v typically)
What am I missing?
Regards
Mark
Main Feed shows way less power than sum of all channels
Re: Main Feed shows way less power than sum of all channels
Can you make sure the PT plug is plugged in all the way? We've had situations where its been plugged in half-way.
Hello Mark,mark_anderson_us wrote:Hi All
What am I missing?
Regards
Mark
If you're indeed using two CT's you will not want to use *Multiply by 2*. With respect to the voltage reading you need to measure the outlet where the PT is installed with a true RMS DMM.
This will let you know what the true line voltage is at the outlet. Taking that data you will adjust the PT *Type*. I am curious did you in fact adjust the range to 4 or was it always like that from the factory?
In my Install thread near the bottom of page five explains the process and what you need to do to adjust the voltage and why some value are used based on the header in place.
NOTE: I also understand the GEM's using the blue PCB boards have the value set to 4. If your board is blue in color you can leave the value at 4 and adjust the *Type* until the GEM matches the values on your true RMS digital multi meter (DMM).
Unfortunately my DMM is still packed (in an unknown box )Teken wrote:Hello Mark,mark_anderson_us wrote:Hi All
What am I missing?
Regards
Mark
It was set to 4 from factory and board is Blue
So I also have 2 240v circuits (AC and Oven) with 2 CT's, I should turn off 240v on those too?
Hello Mark,mark_anderson_us wrote:Unfortunately my DMM is still packed (in an unknown box )Teken wrote:Hello Mark,mark_anderson_us wrote:Hi All
What am I missing?
Regards
Mark
If using two CT's you should disable multiply by 2. This feature is only used for those having one CT in place which helps people save on CT cost etc.
If your board is blue leave the value of 4 in place. Once you locate the DMM you can fine tune the PT value to reflect real world conditions.
Ideals are peaceful - History is violent
