I have seen reference to a TCP2 setting mentioned in recent firmware that would allow me to post while in server mode. I am running COM 3.24 and ENG 1.49, but when I go to network, it says:
"This GreenEye Monitor has a Wifi/Ethernet combination module installed.
Network setup is accomplished using a dedicated network setup page which is incorporated into the module."
Is this option only available for someone with the wifi/ethernet V2 combo?
thanks,
Joe
New TCP2 Setting
Re: New TCP2 Setting
How old is your GEM? It's only available to V2s, but we haven't sold V1s in a long time.rjsmith0 wrote:I have seen reference to a TCP2 setting mentioned in recent firmware that would allow me to post while in server mode. I am running COM 3.24 and ENG 1.49, but when I go to network, it says:
thanks,
Joe
It was purchased in January of 2014. I just used the network utility to tell the GEM I had a V2 and the option is now available. I may have mistakenly set it as a V1 previously thinking I had the older model. Thanks!
We can verify it's V2 if you want to email me over a picture of the WiFi/Ethernet module (ben(at)brultech.com).rjsmith0 wrote:It was purchased in January of 2014. I just used the network utility to tell the GEM I had a V2 and the option is now available. I may have mistakenly set it as a V1 previously thinking I had the older model. Thanks!
