Firmware Update Failure and failed recovery
I have been running my Ethernet/Wifi GEM for over a year now without any issues until recently. I noticed that my GEM would go offline and I would get an email from SEG stating such. When this happens, it would be unresponsive to pings or other network communication but a manual reboot would always resolve the problem. I have been polling the GEM via wifi from two separate systems, btmon for historical data and CQC driver for live data on my HA system. They work fine for a while, but go offline after 8-12 hours. If I disable one of the two polling systems, the system seems to be rock solid.
I thought I would try setting it up with the wired lan connection in case the problem was wifi related. Unfortunately I can never get a link using the LAN port. Today I noticed 3.24 is out and thought I would update with the hope there might be a fix to my problem. I was previously running 3.18 COM and 1.49 ENG. I first tried to run the update using the web interface. That failed, so I tried again using the Network Utility. It got to about 30% complete and appeared to hang. After hanging on the firmware update, I can connect to port 80, but not on port 8000.
I attempted to place it into recovery mode, but it doesn't appear to let me set the baud rate to 19200. When I apply the change to the port, the site appears to hang and the GEM disappears from the network (won't respond to ping) and doesn't come back. When I reset it, I am able to reconnect on port 80 and it is back to 115200 again. I have tried to force the firmware update at 115200 via the network utility and it doesn't get past 0%. I have tried to establish a direct connection via the serial ports and am unable to establish a connection. I have pulled the battery and tried every solution I could find on the forum.
Does anyone have any other suggestions?
Joe
Joe
Re: Firmware Update Failure and failed recovery
I have had some success. I completely removed the wifi/ethernet module and I was then able to connect and recover the firmware. Prior to that, any action I took on the web interface, such as changing the baud rate, resulted in the COMM light going out and me losing connectivity to the device. With it update, I added back the wifi/ethernet interface and now when the unit starts up, the COMM light comes on and I am able to ping the device for a few seconds confirming connectivity and then the COMM light turns off and I lose my connection. I have had nothing but problems with this wifi/ethernet interface since day one and have never been able to successfully able to establish a wired ethernet connection (I am a network engineer by trade).
I am open to any suggestions. In the meantime, I am going to try and flash back to 3.18 and see if the problem is 3.24.
thanks,
Joe
thanks,
Joe
I reverted back 3.18 and it didn't make any difference. What appears to be happening now is that the unit will startup and both LEDs will be green indicating a link to COMM. The unit will respond to a ping, and when I connect to the web interface, I am prompted for authentication. After authentication, it attempts to load the page and then the COMM light immediately goes out and will not come back on until I power cycle the unit. This is reminiscent of the problems I have been having for over a month now, but instead of happening after 8-12 hours of uptime, it happens immediately.
I have tried to reset the comm interface by holding the reset button for 6 seconds and it appears to reset, but then immediately connects to the wireless and responds via the old IP, so I know it isn't resetting. Is there a way to jumper-reset the wifi/ethernet interface? I would love to hear from someone with more experience with this module. I am sure someone from Brultech will be along shortly. After spending 6+ hours on this today I am about ready to take a hammer to it and just go serial. I assume there is a good reason there is a V2 combo interface available now...
Joey
Joey
One more finding before I finally give up and turn in. If I don't try to connect to the wifi/ethernet interface management page directly, I AM able to poll the device with btmon and CQC at port 8000 since my previous "Server" config is still present, but the instant I log into the communication board management page, it loses connectivity and the COMM light drops out. So it appears to be functioning for now as a pass thru device only. I don't know how long that will last though. I suspect if I was able to successfully reset it, it could either help or completely stop working. altogether.
Dropped offline after less than 4 hours.
With yesterday being Canada Day, I suspect I may not hear back from anyone until Monday. I may attempt setting up a Lantronix serial server in the meantime unless anyone has other suggestions.
Joe
Joe
Joe,
How old is the unit? Do you have a Mini-USB and a 5VDC USB adapter around?
Try ditching the 5V adapter and using a Mini-USB or a different 5V adapter (500mA-2A, center positive barrel plug, 2.1mm * 5.5mm). I would suspect a bad power supply if removing the WiFi/Ethernet module allowed you to do things to the GEM (and the COMM LED dropping out).
Thanks for the reply. Mine was purchased in february of last year. My serial number is 875. I do not think I have a Mini USB adapter on my unit. I probably do have a different 5V adapter in my stockpiles. I will check when I get back home and give it a go.
Every GEM has the mini-USB port, it's between the PT and 5V inputs.rjsmith0 wrote:Thanks for the reply. Mine was purchased in february of last year. My serial number is 875. I do not think I have a Mini USB adapter on my unit. I probably do have a different 5V adapter in my stockpiles. I will check when I get back home and give it a go.
I found a USB power supply and after connecting it, it seems to have resolved all of my issues. Not only can I connect to the network management interface successfully without losing the COMM interface, but I also have a link when using a wired connection (first time since I have owned the GEM). I suspect this will resolve all my problems, but time will tell. Thanks so much for the help!
