GEM Wifi/Ethernet V2 Intermittant operation
Posted: Sat Feb 07, 2015 10:09 am
by AllanMar
I've been using my new GEM for about a week now and it's set to send data every 30sec. I've noticed that every one and a while (20-30mins), it stops sending and doesn't come back for probably another 30+mins. It will come back if I use the network config page to reset the Ethernet module. I'm not sure if this is related to Wifi or not?
I'm currently using Wifi and I'd rather not, but I couldn't get wired configured correctly. It appeared as though it was not getting the DHCP settings (no DNS server). The only way I could get DHCP to work was using Wifi.
Also, even through the module is set to STA mode, it still has the AP available? How do I disable the AP?
Re: GEM Wifi/Ethernet V2 Intermittant operation
Posted: Wed Feb 11, 2015 12:06 pm
AllanMar wrote:I've been using my new GEM for about a week now and it's set to send data every 30sec. I've noticed that every one and a while (20-30mins), it stops sending and doesn't come back for probably another 30+mins. It will come back if I use the network config page to reset the Ethernet module. I'm not sure if this is related to Wifi or not?
If an AP is available, that usually means that the WiFI/Ethernet is having issues connecting to your router.
Can you check the signal strength of your router near the GEM via a cellphone/laptop?
Posted: Wed Feb 11, 2015 4:23 pm
by AllanMar
Ben,
Don't want to keep two conversations going (email and here), but since this was a different question.
The GEM is about 3ft from my router, when i check on my router status page it indicates 95-100% signal (best of all my clients). I also don't seem to have issues connecting to the module config page via wifi.
Posted: Thu Apr 02, 2015 9:08 am
by Zhentar
I'm having similar issues (although on the scale of days, rather than just 30 minutes at a time), and the Greeneye AP is always visible.
Posted: Thu Apr 02, 2015 9:47 am
Zhentar wrote:I'm having similar issues (although on the scale of days, rather than just 30 minutes at a time), and the Greeneye AP is always visible.
There's a setting under the GreenEye Advanced settings in the setup webpage called COM1 Auto Reset. This will periodically reset the WiFi/Ethernet module, it generally helps keep a stable connection.
Try setting it to "250".
Posted: Fri Apr 10, 2015 11:45 pm
by Zhentar
I've almost tripled my previous uptime record at this point, so I think it's safe to say that did the trick. Thanks!
Posted: Fri Apr 17, 2015 11:09 pm
by robbert2012
I have similar issues. My GEM quit responding/sending over wify to my dashboard. My GEM also didn't respond to a ping. I rebooted the GEM and it connected again,
I did just now set the auto-restart to 250 as suggested.
However, it doesn't look like the GEM wifi is as reliable as it should be. So I think I will move my dashboard and connect it to the GEM with the serial cable.
Bert
Posted: Sat Apr 18, 2015 9:48 am
robbert2012 wrote:I have similar issues. My GEM quit responding/sending over wify to my dashboard. My GEM also didn't respond to a ping. I rebooted the GEM and it connected again,
Bert
Hello Bert,
I believe wiring with the serial cable is indeed the best and most robust method.
Posted: Mon Apr 20, 2015 11:07 am
Bert
Is this a WiFi-only unit? That module has an issue where it'll sometimes get stuck trying to re-establish a connection. Setting the Auto-Restart solves this. It connects up to the router very quickly so there shouldn't be any noticeable consequence of doing so.
