The line graph will show voltage averaged over the minute, is it possible you lost power for a second?Teken wrote:Today at 12:20:59 AM I received a text the voltage in the house dropped to 2.72 VAC. The DB indicates also 0 VAC condition? Looking at the actual DB line graph for that time does show a drop in voltage to 104.6 VAC.
I will confirm this from the two other data loggers and report back. What I believe is the system is able to detect extremely fast pulses of line variation. The two devices (appear) to provide a snap shot of that condition even if its exaggerated in this one case.
All other times there have been no collaborating evidence to say either way. I will post up a screen shot later for review etc.
Zigbee Diagnostic - Tracking Data Packets
Re: Zigbee Diagnostic - Tracking Data Packets
At this point I am unsure but can only offer what data I have available. The DB does indeed show a drop in line voltage to 104.6 VAC.ben wrote:The line graph will show voltage averaged over the minute, is it possible you lost power for a second?Teken wrote:Today at 12:20:59 AM I received a text the voltage in the house dropped to 2.72 VAC. The DB indicates also 0 VAC condition? Looking at the actual DB line graph for that time does show a drop in voltage to 104.6 VAC.
The two data loggers I have do not show anything and they are set to a very fine level as seen below.
- Voltage Drop.PNG (64.04 KiB) Viewed 944 times
- Voltage.PNG (60.55 KiB) Viewed 944 times
- Settings 3.PNG (42.64 KiB) Viewed 944 times
- Sag Event.PNG (40.52 KiB) Viewed 944 times
What COM/ENG are you running?
We had an issue at one point with the GEM failing to transfer voltage once in awhile, all readings are fine just the voltage gets set to 0. Might be related to that.
Ben,ben wrote:What COM/ENG are you running?
I do believe this is related to that issue hence why I updated the GEM to all the latest releases. I am indeed using COM 3.18 / Engine 1.49.
Please also ask Paul if the latest firmware resolves the 1 wire sensor issue. I have not attempted to reconnect the one last sensor back into the GEM because it freaked out and took the sensor grid down.
