WiFi/Ethernet is usually pretty solid, in your case I would try enabling COM1 Auto Reset with a high value like 250 to ensure a solid connection.zintrinsic wrote:I had a similar issue with the one reported here. The connection to SEG dropped twice: approximately 3 days after I first turned it on and approximately 3 days after I reset it.
I have a WiFi/Ethernet module and am using the WiFi connection.
Per your recommendation I set COM1 to Auto Reset and disabled Flow Control. I've now made it past 4 days. Hopefully that did the trick. I will post again if I have any problems again.
GEM connection to Smart Energy Groups (SEG)
Re: GEM connection to Smart Energy Groups (SEG)
Thanks. It's been working great since I made that change. Only had one drop when my internet provider was down for a bit. As soon as the provider came back up, the data started coming through again.
