TCP peer keeps closing connection
I have a new GEM, w/ wifi only. GEM Network utility V 5.9 running, baud 19.2, "normal", idle time 12, wifi version 4.41. Connection Status = "Connected" but the box is red. I have ECM Engine V2.49. The problem is, the TCP connection keeps getting reset once every 30 seconds or so. i see "Connected to Ethernet Gateway Via TCP/IP", then "TCP Server A Closed", then "Connected to Ethernet Gateway", then "Connected to Ethernet Gateway via TCP/IP", then "TCP Server A Closed". this whole cycle takes about 30 seconds and repeats. When the connection is closed, "Connected" changes to "Peer is closing connection" and the cycle repeats. Suggestions? I am trying to do a local web server with the monitor dashboard software displaying locally, but there is no data being displayed. Suggestions? Thanks
Re: TCP peer keeps closing connection
There's an idle time setting for the WiFi module, this setting tells the module to disconnect after X seconds of inactivity. You'll want to change it to 0 to ensure a persistent connection.gusa1 wrote:I have a new GEM, w/ wifi only. GEM Network utility V 5.9 running, baud 19.2, "normal", idle time 12, wifi version 4.41. Connection Status = "Connected" but the box is red. I have ECM Engine V2.49. The problem is, the TCP connection keeps getting reset once every 30 seconds or so. i see "Connected to Ethernet Gateway Via TCP/IP", then "TCP Server A Closed", then "Connected to Ethernet Gateway", then "Connected to Ethernet Gateway via TCP/IP", then "TCP Server A Closed". this whole cycle takes about 30 seconds and repeats. When the connection is closed, "Connected" changes to "Peer is closing connection" and the cycle repeats. Suggestions? I am trying to do a local web server with the monitor dashboard software displaying locally, but there is no data being displayed. Suggestions? Thanks
