COM 3.16 / ENG 1.49 Release Notes
Hello All,
I installed COM 3.16 / ENG 1.49 when it was released last week. The GEM is running like a champ and did not see any obvious UI changes or options.
So, what's under the hood that has been changed?
I am currently tracking any power / temperature spikes which does not seem to have occurred as of late. I still receive e-mail alerts from the ISY Series Controller that the system has detected a negative energy value from my fridge from time to time.
I have placed Brultech / UDI on the mailing list so you can monitor the frequency of this issue along with the voltage issue. One of the things I also did was add in the Dash Box via state variables to the e-mail alert for comparisons.
I believe doing this has provided some insight but what it is I really can't say. If I use the ISY's default alert this will always provide me the negative values I have seen. When the Dash Box sends out the same information the actual (current wattage) is not in a negative state which in the big picture is good!
Maybe this will help the two companies narrow down where and why this issue persists. I will upload a screen shot and high light the information for more clarity.
Re: COM 3.16 / ENG 1.49 Release Notes
I'll have to get Paul to get me the release notes, I think there was some changes to the temp sampling to prevent invalid reads from the temp sensors.
That would be great as he reached out to me indicating a 10K resistor placed in parallel would resolve why one of the existing sensors could not be enrolled again.ben wrote:I'll have to get Paul to get me the release notes, I think there was some changes to the temp sampling to prevent invalid reads from the temp sensors.
When I installed the Autelis Bridge there were a few extra 1 wire sensors on hand. When I tried to add one of the new ones to the GEM it freaked out and took the entire 1 wire network down.
Later on I tried to add back the (old existing) sensor to the GEM but had the same problem? This is when Paul indicated a 10K resistor would solve this issue?
Looking forward to his reply as I have another 20 sensors enroute!
Sent this to him in an email.Teken wrote:That would be great as he reached out to me indicating a 10K resistor placed in parallel would resolve why one of the existing sensors could not be enrolled again.ben wrote:I'll have to get Paul to get me the release notes, I think there was some changes to the temp sampling to prevent invalid reads from the temp sensors.
Just circling back to see about the release notes.
Were these ever posted anywhere? I looked in the firmware section and did not see any comments in the "change log".Teken wrote:Just circling back to see about the release notes.
There were no release notes provided.
The patches since 3.12 are mostly fixing one or two bugs here and there and internal stuff to do with the small GEM revision we made (WiFi/Ethernet on-board instead of external connector).
Most of the stuff only affects a small portion of users (besides the amp display bug).
ver 3.12
- Fixed problem with ^^^RQSRTL requesting realtime status.
3.16
- Removed VA in setup page live data
- Added "Com1" and Com2 to Pri and secondary packet format label in setup page
- Made change to help prevent GEM from being stuck in web setup mode.
3.17
- Fixed problem with CHxx and CHE commands.
3.18
- Display of amps fixed in live data section of setup website.
3.19
- Fixed problem where sending SYSPKT4 would set PKT to 5 if the leading zero was not included.
- Fixed same problem as above but for PKF which is the secondary packet format.
- Fixed RQSPKT which did not work.
ver 3.12
3.16
3.17
3.18
3.19
Ben,ben wrote:The patches since 3.12 are mostly fixing one or two bugs here and there and internal stuff to do with the small GEM revision we made (WiFi/Ethernet on-board instead of external connector).
ver 3.12
3.16
3.17
3.18
3.19
Thanks for the break down for the COM firmware releases. Is there any information pertaining to the Engine updates?
It's just stuff to do with the new revision most likely. Nothing that'll make much sense to the end user.
