Is it possible to connect two devices that can capture, display, the 1 wire temperatures readings at the same time?
For example: If I had two GEM's and one of them had an existing 1 wire network in use. Could I simply tap off the data line in parallel to obtain the same readings? To expand on this use case if I had a GEM with an existing 1 wire network.
Could I then tap into the data line from the GEM and parallel that same data line to a third party device?
I do realize that I would have to first enroll each of the sensors to the new device so it could see and know which sensors readings applied to what. Is there a problem tying two independant systems data / ground wires together?
Any insight to this would be most helpful as I am trying to reduce another 1000 foot run of cable assuming the above solution is not viable.
Much Thanks
1 Wire Temperature - Is it possible to connect in parallel?
Re: 1 Wire Temperature - Is it possible to connect in parall
Passed this over to Paul.
Ben,ben wrote:Passed this over to Paul.
Much appreciated!
Guess you could just try it in the meantime if you have another 1 wire controller.
