From the GEM Network Utility Ver 5.8, there are 3 settings for Comm Setting: (On Ethernet Only Tab)
Packetize Time: 10 /* Is this milliseconds */
Packetize Size: 1800 /* Is this bytes */
Idle Time: 30 /* Is this milliseconds*/
Can you please explain:
1. What each does.
2. What do the values represent? 10 / 1800 / 30
3. What are the default values?
4. Can I Read/Set these values using the API?
If so I don't see them in documentation.
GEM Network Utility - Packetize Time / Packetize Size / Idle
Re: GEM Network Utility - Packetize Time / Packetize Size /
Packetize Time and Size shouldn't be touched, the default values are what we found works best. We'll likely be removing them in a newer version.TymerTopCat wrote:From the GEM Network Utility Ver 5.8, there are 3 settings for Comm Setting: (On Ethernet Only Tab)
1. What each does.
Idle Time is the amount of time of inactivity the module will wait before it disconnects. This allows Mixed Mode to work. If you don't need a persistent connection to data log, it should be set to a value lower then your send interval.
The GEM doesn't control these values, it's controlled by the WiFi or Ethernet module.
I would ask that you not remove these settings.
Why?
I am currently writing a TCP/IP access method, to use the Data Polling API.
Since I have 4 greeneyes I was testing the TCP connection responses and I
noticed that 1 of the 4 Greeneyes was fragmenting the packets, meaning instead
of sending 625 Bytes for a BIN48-NET-Time (4) packet. I was getting 1-4 bytes
at a time instead of the usual 625 bytes. I was using the Socket Class in Microsoft
Windows Visual Studio 2010, via Socket.Read() which returns the number of bytes
read.
I fixed this by changing the values from:
Packetize Time: 0
Packetize Size: 0
Idle Time: 255
to
Packetize Time: 10
Idle Time: 30
This makes for a more robust application on my side.
-Russ
Why?
read.
Packetize Time: 0
Packetize Size: 0
Idle Time: 255
to
Packetize Time: 10
Idle Time: 30
-Russ
Can you please answer Questions 2,3,4 from my original post?
Tks.
-Russ
Tks.
-Russ
I don't really have a good answer for that, they're settings that come from the factory with the module. I think it's time to build a packet, and size before it spits out the packet.TymerTopCat wrote:Can you please answer Questions 2,3,4 from my original post?
Tks.
-Russ
EDIT:
Length (2 Bytes)
Input serial data packing length. When the input serial data length reaches to
the value, it will be sent out. Please, note that only the low 1 byte is used and
the maximum length is 0x00FF. 0 means the packing condition is disabled.
Interval (2 Bytes)
Input serial data packing interval, which indicates how long to send the input
serial data once. 0 means the condition is not used and 0xFFFF is the
maximum interval in millisecond.
They should be all set to 10/1800 (defaults in our software) as that's what we found works best also.
Check your PM for commands.
