On the next update to the GEM manual, could you add some verbiage on using multiple type A CT's on a channel. I had two split 200's working great, but got kicked out of the POCO's box, so had to use 2 split 200's on my 200 Amp panel and 2 split 200's on my 135 Amp panel. Via research I figured out that type A CT's have to be wired in series / not parallel. Then getting the 2 series CT's on the same phase in the correct polarity. Working fine now, but a diagram would have saved a bunch of time / research
..Barry
GEM Manual update - Split Panel S200 CT's
Re: GEM Manual update - Split Panel S200 CT's
I'll let Paul know.bgrubb1 wrote:On the next update to the GEM manual, could you add some verbiage on using multiple type A CT's on a channel. I had two split 200's working great, but got kicked out of the POCO's box, so had to use 2 split 200's on my 200 Amp panel and 2 split 200's on my 135 Amp panel. Via research I figured out that type A CT's have to be wired in series / not parallel. Then getting the 2 series CT's on the same phase in the correct polarity. Working fine now, but a diagram would have saved a bunch of time / research
..Barry
