Post
by ben » Wed Jun 18, 2014 12:55 pm
ps0ps wrote:I still can't get the eng firmware to load.. same error after i flash the com to 2.50.. I've forced the rs232 to 19200 and nothing changes and again, the sys led turns off after a bit
Do a Get GEM Info and attach a screenshot for me.
ps0ps
Post
by ps0ps » Wed Jun 18, 2014 1:32 pm
Here you go... It shows ENG 1.47, but I still have no wifi or wired ethernet connectivity and I've never been able to re-flash it.
- Screenshot 2014-06-18 11.31.11.png (112.35 KiB) Viewed 1316 times
Post
by ben » Wed Jun 18, 2014 1:35 pm
ps0ps wrote:Here you go...
Are you connected to COM1 or COM2? If COM2, try moving the cable to COM1 and try the same thing (Get GEM Info).
The Firmware tab Baud Rate buttons will only control the baudrates on COM1.
ps0ps
Post
by ps0ps » Wed Jun 18, 2014 1:47 pm
FWIW, unscrewing and disconnecting the wifi module brings the other LED online, but I still don't have wired ethernet connectivity. If the wifi is plugged in, the second LED never comes online.
ps0ps
Post
I'm wired up to COM1
Post
by ben » Wed Jun 18, 2014 2:09 pm
ps0ps wrote:FWIW, unscrewing and disconnecting the wifi module brings the other LED online, but I still don't have wired ethernet connectivity. If the wifi is plugged in, the second LED never comes online.
Put the GEM into Recovery Mode and try to reset the WiFi/Eth module by holding in the button for 6 seconds (the button on the side of the actual Comm. module). It may take around 30 seconds to a minute for a full reset.
After check your wireless networks to see if it appears.
ps0ps
Post
by ps0ps » Wed Jun 18, 2014 10:04 pm
good news, new power supply arrived today and that fixed it.. go figure
Post
by ben » Thu Jun 19, 2014 9:55 am
ps0ps wrote:good news, new power supply arrived today and that fixed it.. go figure
When did you order the GEM?
ps0ps
Post
by ps0ps » Thu Jun 19, 2014 11:43 am
March 5th, 2014
