Updated the GEM to the latest COM 2.58 just moments ago. The loading went very smooth with GEM Network Utility v5.8. I did observe again that the KWH were deleted from the ISY controller? This time it seems like 5-6 of the channels were blown away instead of all of them?
I reported about this odd behavior in the previous release as well in 2.55 but did not receive any feed back about this.
Right now the GEM is running like a champ and is rock solid.
COM 2.58 Firmware
COM 2.58 Firmware
Re: COM 2.58 Firmware
Maybe you can try something for us with the latest firmware. Try enabling Auto-Reset on the Zigbee module, set it to 20. This will make your Zigbee module reset every 30 minutes.Teken wrote:Updated the GEM to the latest COM 2.58 just moments ago. The loading went very smooth with GEM Network Utility v5.8. I did observe again that the KWH were deleted from the ISY controller? This time it seems like 5-6 of the channels were blown away instead of all of them?
We're working with UDI on fixing some of the issues.
Ben,ben wrote:Maybe you can try something for us with the latest firmware. Try enabling Auto-Reset on the Zigbee module, set it to 20. This will make your Zigbee module reset every 30 minutes.Teken wrote:Updated the GEM to the latest COM 2.58 just moments ago. The loading went very smooth with GEM Network Utility v5.8. I did observe again that the KWH were deleted from the ISY controller? This time it seems like 5-6 of the channels were blown away instead of all of them?
I hope your interaction with UDI will also address the *current / amps*, temperature, pulse, data not being available from the GEM.
Right now, we're just working on fixing up the problems that have been reported.Teken wrote:I hope your interaction with UDI will also address the *current / amps*, temperature, pulse, data not being available from the GEM.
