Post
by ben » Thu Mar 20, 2014 11:08 am
rnoble wrote:
I just rebooted and the times at the top of the page are correct... Is that what you're referring to?
Yeah, if that syncs then your internet connection is fine.
Can you take a screenshot of your SEG page (blank out the token id)?
Post
by Teken » Thu Mar 20, 2014 11:08 am
Ben,
Ryan is using 4.1.5E on the Dash Box already.
rnoble
Post
by rnoble » Thu Mar 20, 2014 11:34 am
Post
by Teken » Thu Mar 20, 2014 11:47 am
Ryan,
I believe he meant the actual web page at the Smart Energy Group not in the Dash Box.
rnoble
Post
by rnoble » Thu Mar 20, 2014 11:53 am
Post
by ben » Thu Mar 20, 2014 12:58 pm
rnoble wrote:
So Discovery does nothing? It says you have a total of 106 API hits so it looks like the packets are making it there.
rnoble
Post
by rnoble » Thu Mar 20, 2014 1:03 pm
rnoble
Post
by rnoble » Thu Mar 20, 2014 1:08 pm
Odd thing is that the API page is showing data...
Post
by Teken » Thu Mar 20, 2014 8:02 pm
Ryan,
Would you please post up all of the GEM set up tab settings either here or via PM. Please also provide a screen capture of the Network Tool.
You didn't change any of the values in the individual streams did you? Such as calibration (1) or the stream name?
Can you select one stream and post up what it looks like for us. The stream name should be e_1, e_2 etc which denotes energy.
I know in the GEM prior to using the Dash Box people were supposed to use the format 14 (New SEG format) which did all of the heavy lifting when sending out the data and set up in Packet Send tab.
Your Raw Data above is correct it must be something really silly I believe.
Post
by ben » Fri Mar 21, 2014 1:15 pm
Had a problem like this once.
I would try manually creating a device with the same Node ID then trying Discovery again.
