I'm trying to move from Homeseer monitoring to a more open system, using the btmon script.
Btmon is reading the ECM1240 OK, but gives an error message and fails to send data to my Emoncms server. The Emoncms server is running on a Raspberry Pi on the local network.
This is the error message.
OpenEnergyMonitorProcessor Error: HTTP Error 404: Not Found URL: http://192.168.0.162/emoncms/input/post ... .00,XXX605
_aux3_w:0.00,XXX605_aux4_w:0.00,XXX605_aux5_w:0.00,XXX605_ch1_wh:568.00,XXX605_ch2_
wh:0.00,XXX605_aux1_wh:0.00,XXX605_aux2_wh:0.00,XXX605_aux3_wh:0.00,XXX605_aux4_wh:0.00,XXX605_aux5_wh:0.00}
token: 913-----------------261
data:
If I paste the URL into a browser on the PC which is running btmon it works fine, creates the fields and populates them.
Any suggestions gratefully received.
btmon.py Error 404 when uploading to oem
Re: btmon.py Error 404 when uploading to oem
bill,
which version of emoncms are you running?
m
m
Thanks for the reply.
It turned out that it was my error, I'd missed out the emoncms/ from the url in the config file and hadn't noticed despite much looking!
