I am using mysql database to save the data comming from GEM device reading from Serial port
the setup of mysql user is %100 working but the btmon can't create the database and the table
is there any way I can create it manualy using the counters Schema ?
or maybe use a sql command to gererate the table with the right filed name and type ?
btmon can't create a database and table
Re: btmon can't create a database and table
what error are you seeing from btmon?
be sure that you grant appropriate permissions. for example, if btmon will connect as 'ecmuser' with password 'ecmpass' from host 'ecmclient', saving to the database 'ecm', you would do the following on the mysql server:
then when you run btmon it will create the table with schema as needed.
if you specify a mysql user that already has permission to create databases then you do not need to do the grants.
the actual sql to create a table is constructed on the fly and depends on the packet format you choose.
m
mysql -u root -p
mysql> create user ecmuser identified by 'ecmpass'
mysql> create database ecm;
mysql> grant usage on ecm.* to ecmuser@ecmclient identified by 'ecmpass';
mysql> grant all privileges on ecm.* to ecmuser@ecmclient;
m
