Hi,
First I'd like to thank Matt for such a nice easy to use script.
I have been having problems with timeouts. I suspect that it has to do with my zigbee connection occasionally dropping out. It will happen a couple of times a day, but once it happens the script can not recover. I notice there is a time out setting (60) when I run the script but I can't see how to change it.
My setup is
2 EMC1240s connected to the network using z wave via
1 etherbee
The etherbee is currently in server mode with
windows laptop running the script in client mode
Right now all I'm doing is sending data to SEG
I have several questions
1) How do I extend the timeout period
2) If I used btmon to save to a database first would that help with the timeout and or could it recapture the data. I know I can manually upload data
3) Can I use the dashboard and upload to SEG at the same time and if so how
Paul
btmon times out
Re: btmon times out
Got it figured out. I needed to up the polling retrys and timeout in the script itself. I may try the database thing later. I'm trying to decide if I want to post to multiple sites or just stick with SEG
K
K
