BTMon dies
Re: BTMon dies
it looks ok from the client side of things, and the 'Status: 200 OK' response from the server indicates that SEG received the data.
you might want to ask sam at SEG if there is a limit to the number of channels that can be posted at once.
check with sam to see if the SEG server logs are complaining about your postings.
also, there might be a limit to the length of a string when making an http post - i'll check the specs and standards.
you can test to see whether the length is the issue by doing one of the following:
1) post to SEG every 15 seconds instead of every 60 seconds (seg_upload_period)
2) use a map to upload only 2 or 3 channels instead of all of them
fwiw, i have periodically experienced gaps in data at SEG when uploading from 8 ECM all at once. btmon gets the 'Status: 200 OK' but no data show up at SEG. once it was due to some server maintenance in progress at SEG. two other times no explanation, and things just started working again after awhile.
generally speaking SEG has been very reliable, but the GEMs might be hitting it with more data than it was ready for. most of the online services are targeted toward whole-house monitoring, so 32 channels is a lot to them.
Re: BTMon dies
not likely. communication with the GEM looks ok.Tirnanah wrote:I am on firmware 1.70 (Engine ver 1.40). Could it be something with that?
if you are concerned about losing data, and since you are saving to database already, you might want to run two instances of btmon - one to collect data and save it to database, and a second to upload data from the database to SEG (and any other services). see the section about running multiple instances of btmon in the guide:
http://lancet.mit.edu/mwall/projects/po ... howto.html
Re: BTMon dies
also, do not leave your configuration posting to SEG at 15 second intervals! it is ok for testing, but once you sort things out switch back to 60 or 90 second intervals.
Re: BTMon dies
I did change the interval to 60 seconds. I don't remember changing it, but I must have. I've also send an email to Sam to see if can check his side.
Thanks for the continued support.
Doug
Doug
Re: BTMon dies
I may have figured this out.
mwall: Does btmon make the adjustment for watt hours prior to upload to SEG? One of the things in the SEG/GEM setup documentation is to put a calibration (multiplication) of .000277 on the SEG site to make the energy data display correctly.
I created an entirely new device to start fresh, and noticed that as soon as I put that calibration in, all of my energy values dropped to 0 and I cannot get any data from them now, whereas before, there was still a little bit of data that was building correctly.
Doug
Doug
Re: BTMon dies
These calibration values are unique to our direct GEM posts to SEG to convert wattseconds to watthours (1/3600000) to take some strain off the GEM itself.Tirnanah wrote:mwall: Does btmon make the adjustment for watt hours prior to upload to SEG? One of the things in the SEG/GEM setup documentation is to put a calibration (multiplication) of .000277 on the SEG site to make the energy data display correctly.
btmon.py looks to send delta watt hours, so you don't need the same value as above.
Re: BTMon dies
Thanks Ben. I'll take those calibration values back out and see what happens.
Doug
Doug
Re: BTMon dies
Success. Data starts to flow again.
Thank you everyone for all the help.
Doug
Doug
