btmon patch for RaspPi Influxdb
Posted: Wed May 04, 2016 10:20 am
by roscoe
Just calling out in case someone has already solved this....
Looking to change my logging from the vintage sqlite/dashboard to using
ECM >> serial >> Raspberry PI > Btmon > InfluxDB
sure could use MQTT, but looking to keep everything tight, I will use grafana as the prettyness provider but not on the pi
any thoughts ?
Re: btmon patch for RaspPi Influxdb
Posted: Wed May 04, 2016 6:51 pm
by mwall
roscoe wrote:Just calling out in case someone has already solved this....
any thoughts ?
hi roscoe,
mark clark has already written the mqtt extension. it is waiting to be merged on github (i plan to do the merge after i can test it more, probably in about 2 weeks' time). look in the pull requests:
https://github.com/matthewwall/mtools
i wrote an influx extension to weewx, and i've been running that for some time now to make sure i got the bugs out. i plan to port that over to btmon as soon as the mqtt changes have been merged.
m
Posted: Tue Sep 20, 2016 11:59 am
by tgmaxx
I am starting out with InfluxDB and Grafana and was just researching if anyone had a ECM-1240 to InfluxDB interface. I was glad to see Matt added the MQTT option to btmon. I can use Node-Red as the interface between MQTT and InfluxDB. But, if there was a btmon output to InfluxDB option, I would use it.
I am running InfluxDB and Grafana on a Pi 2 and everything is fine.
Posted: Tue Sep 20, 2016 1:27 pm
by mwall
tgmaxx wrote:I am starting out with InfluxDB and Grafana and was just researching if anyone had a ECM-1240 to InfluxDB interface. I was glad to see Matt added the MQTT option to btmon. I can use Node-Red as the interface between MQTT and InfluxDB. But, if there was a btmon output to InfluxDB option, I would use it.
mroch and roscoe57 have been tweaking an influxdb pull request. you might give that a try and let us know how it works for you.
https://github.com/matthewwall/mtools/pull/4
i plan to merge the pr as soon as it is sufficiently tested.
Posted: Tue Sep 20, 2016 3:36 pm
by tgmaxx
Ok thank you. I will check it out.
