Hi All
I have two 1240's connected to mux and want to connect each one to dedicated serial port (40 ft cables). Anyone know the wiring setup to go direct from 1240 to DB-9?
thanks
Mark
Serial Cable Pin-out
Re: Serial Cable Pin-out
It's the same for the GEM and ECM-1240, bottom-right of the diagram has the pin-out.mark_anderson_us wrote: I have two 1240's connected to mux and want to connect each one to dedicated serial port (40 ft cables). Anyone know the wiring setup to go direct from 1240 to DB-9?
ben wrote:It's the same for the GEM and ECM-1240, bottom-right of the diagram has the pin-out.mark_anderson_us wrote: I have two 1240's connected to mux and want to connect each one to dedicated serial port (40 ft cables). Anyone know the wiring setup to go direct from 1240 to DB-9?
