How do I configure this? Under help it shows.
Setting the IP address and port number of the ECM Server Software (default: IP=127.0.0.1 on port 8084)
My ECM Engine 2.48 is running on a PC with the IP address of 10.0.0.249. What port should I use? Do I need to config forward data? Under TCP/IP Port A it is set to port 6939. I run a web server on that box using port 9009 that hosts the Brultech data.
ECM Toolbar 1.4
Re: ECM Toolbar 1.4
Under the Forward Data menu, there's an option called "Home Automation Plugin". You want to go to Custom and set it as a TCP/IP Server, probably just set the TCP/IP server port to 8084.Judgeless wrote:How do I configure this? Under help it shows.
